Fiber pices in oil
Norman
11-26-2001 17:43:44
I asked this a few days ago, but somehow my post dissapeared.
Its been a while since I completely rebuilt my 51 8N. On a recent oil change I found some fiber pieces that look like bits of a fiber gear. Probably the oil pump teeth. As the timming gear and the crank gear are metal, I think the oil pump gear is the only fiber gear in there. Anyone have any input on this. I was trying to see if I can change this out without removing the front and the oil pan again. If so I may now wait till spring. I still have good oil pressure.
Nogrimace
11-27-2001 10:30:16
 Re: Fiber pices in oil in reply to Norman, 11-26-2001 17:43:44
I rebuilt my oil pump this past year, my gears were metal and not fiber type. I don't know the history on your tractor, but maybe some where along the line after market parts may have been used, thus the fibers. If you have good oil pressure, then I wouldn't worry about it. If you tried to second guess all the Foreign objects and where they came from when you work on the old girl you could spend a life time replacing and reworking things. Good luck.
