Let it snow!
Alan MN
11-26-2001 20:42:59
I'm like a kid Christmas eve. It finally snowed here in MN. I get to try out my new-to-me 8N with the snow bucket. Can hardly wait to wake up and start playing. I know this will wear off soon, so I want to enjoy it while it lasts.
rich in n minn.
11-27-2001 06:57:53
 Re: Let it snow! in reply to Alan MN, 11-26-2001 20:42:59
Hi guys:
I am in n minnesota and we only have a couple of inches of snow. I loved it last night though with all the snow falling, wind howling and I was in the barn with my 2n and 8n. I put the chains on the 8n thanks to a nice post here on the board archives, I finally found an easier way to put the chains on - thanks guys. I have the original dearborn front mounted blade for the 8n that has the chains. My 2n has a single stage 5 foot Erskine snowblower that works great. I don't have chains on this tractor and that seems to work best because If I am spinning a bit and that is better because I want max pto and slower speed. I tried chaining up the 2n and with max speed for the pto I found that 1st gear was too fast with most snow accumulations. I have been using these rigs for about 5 years and I still haven't got tired of my winter snow removal. My driveway is about a 1/4 mile long and I haven't had to call in the big snowplows yet
Always curious about easier ways
11-27-2001 08:50:31
 Re: Re: Let it snow! in reply to rich in n minn., 11-27-2001 06:57:53
Can you provide a pointer to the easier way to put on chains?
Thanks,
Jerry
rich in n minnesota
11-27-2001 09:34:57
 Re: Re: Re: Let it snow! in reply to Always curious about easier ways, 11-27-2001 08:50:31
Regarding putting chains on the tire, perhaps you guys already knew this but I am still learning. Anyway, make sure the hooks on the indiviudal cross chains are to the outside not facing the wheel. Take the part of the chain that does not have the fasteners and pull it over the tractor tire from back to front tucking the first cross chain under the tire. Drive forward over the chain until the fastener is axle high on the back of the tractor tire. Pull the tire chain up to the fastener (easier said than done) and hook the fastener. Note - do the inside fastener first then, the outside. Drive a short distance and then see if you can tighten the fastener another chain link or two.
Hope this helps, I did not bookmark the section in the archives but if you do a search on tire chains, you may be able to find something in the archives.
Trapper
11-27-2001 06:49:35
This is from last Dec 12 here in SE Michigan.
I'm not quite ready yet as I'm building a front blade for the loader.
Remember to take pictures (ED-Illinois)
11-27-2001 06:34:26
It is a lot more fun to think about plowing snow when you are inside rather than when you are out in the cold....
third party image
So take pictures, sit by the fire, and grin!
Ultradog MN
11-27-2001 06:24:52
Welllll
I guess it still came a bit too early for me.
Or did I just procrastinate too long?
I haven't finished building my front mount snow plow. It's coming along though. Got the frame mostly built and have all the hydraulics figured out.
I'm using the 3 pt to push a hyd. cylinder
which will raise and lower the plow.
This unit is going to be so neat you're all going to want one.
Gotta give credit to my neighbor here. Man is he smart!
Meanwhile, guess I'll get the shovel out...
Alan MN
11-27-2001 06:21:10
Now that was fun. I don't think this will wear off anytime soon. We got around 9" of the wet heavy stuff. It's all I can do to keep from doing everyone's drivway on my street. I played with the bucket and the back blade. I must admit the back blade seems to work easier for me. It's the first real work out I've given my 8N since I got it a couple weeks ago. I don't know how I ever got by without it.
Ultradog MN
11-27-2001 06:27:08
 Re: Re: Let it snow! in reply to Alan MN, 11-27-2001 06:21:10
Where in MN are you?
I'm in Mpls.
Alan MN
11-27-2001 18:46:10
 Re: Re: Re: Let it snow! in reply to Ultradog MN, 11-27-2001 06:27:08
Up between North Branch and Taylors Falls.
Dan
11-27-2001 05:32:55
OK. You three are obviously experts. Do you use plow or blower? Is it difficult to mount a fairly modern snowblower on an 8N? i.e. do I have to modify the tractor? Thanks, Dan
ED-Illinois
11-27-2001 06:40:27
 Re: Re: Let it snow! in reply to Dan, 11-27-2001 05:32:55
Check the archives - last year was the first time I saw a single stage snow thrower for a cat. 1, 3-point hitch. In essence, it was a V shaped blade that moved snow to the center of the V as the tractor moves foreward. At the center of the V is an impeller driven by the PTO shaft. The snow is pushed up from the impeller and a two position fin directed the snow iher left or right. Pretty cool, but I couldn't hlp but think what would happen if one fell off the seat. Of course, one needs to be cautious whenever using the tractor.
I personally use a blade
Here is the Picture (ED-Illinois)
11-27-2001 06:45:29
 Re: Re: Re: Let it snow! in reply to ED-Illinois, 11-27-2001 06:40:27
I found it in the photo archive!
third party image
Every time I see it I think I might want to get one.
Dan
11-27-2001 08:38:43
 Re: Re: Re: Re: Let it snow! in reply to Here is the Picture (ED-Illinois), 11-27-2001 06:45:29
third party image
Great photo, thanks. I want it now! Looks like it hooks right up to the PTO and three point. Anybody got an idea who made it? I've attached a photo that I found 'somewhere' on the web. The file name was "pto driven erskine".
ED-Illinois
11-27-2001 09:31:40
 Re: Re: Re: Re: Re: Let it snow! in reply to Dan, 11-27-2001 08:38:43
Found this on the internet...
Erskine Mfg. Co. PTO powered snow blowers for larger tractors. 121 Bradley Blvd., P.O. Box 100, Erskine, MN 56535, (218) 687-4045.
OOOPPPSSS!!! (ED-Illinois)
11-27-2001 09:35:54
 Re: Re: Re: Re: Re: Re: Let it snow! in reply to ED-Illinois, 11-27-2001 09:31:40
Just called to get info and they stopped making them last year!!!
Argh - ed
Dan Derby
11-27-2001 10:00:36
 Re: Re: Re: Re: Re: Re: Re: Let it snow! in reply to OOOPPPSSS!!! (ED-Illinois), 11-27-2001 09:35:54
Woods (the mower people) make 'em. Just found this, their small tractor model: >Link
If>Link you want to buy new that is.
Dan
ED-Illinois
11-27-2001 10:43:56
 Re: Re: Re: Re: Re: Re: Re: Re: Let it snow! in reply to Dan Derby, 11-27-2001 10:00:36
Problem with that is you have to drive backwards - the other kind lets you drive foreward.
Thompson8N167346 - no snow in Manitoba, sigh...
11-27-2001 04:39:30
I've got the blade on my 8N and the blower tuned up and ready to go. But it just won't snow - there isn't even frost in the ground yet! This is very, very strange for here. I'm fully expecting to pay for this in a big way.
December's long range forecast is for above average precip. and below normal temps.
bj/8N/mt
11-27-2001 03:25:41
Hasn't worn thin for me in ten years here in Montana. Still enjoy getting on the Carharts and plowing the driveways here and next door.
Only six inches of valley snow here so just a tune up really.
Your mileage may vary
Sal
11-26-2001 21:17:36
I know what you mean it is fun to move the snow around for a while.
But that steel seat and lack of an enclosed cab makes it a bit of a challenge after a while.
Here in Syracuse NY (191" last year) we haven't even had a trace. I have not put on my field chains or my blade yet since there is no snow in our 7-10 day forecast.
Still, I can't wait to plow a few times.
This year I now have a rear utility light...that will be great for the short days!
