Order Ford 8N Parts Online
Increasing torque on 8N
randy blaiser
11-29-2001 10:30:20
I have 28 inch tires and I want to put on smaller tires like 24 inch ones and drill different holes on my rims to fit my hubs. my friend says this should help increase my torque and pulling ability and give me more rod speed becasue the tires will spin faster. I told him that it will only go a little faster when I am pulling rocks. Can someone help me tell my friend what smaller tires do on an 8N?
raytasch
11-29-2001 10:46:57
 Re: Increasing torque on 8N in reply to randy blaiser, 11-29-2001 10:30:20
Your friend is wrong. Smaller outside diameter tires will decrease your tractor speed. For any given engine speed your over the ground speed will be less if you install smaller drive tires. As far as pulling ability I would have you consider what the ground surface would be. You may loose traction when you go to smaller tires. There is a lot to consider when changing tire size. BTW, you can buy smaller rims to fit your 8N hubs.
ray
yep . . .Dell (WA)
11-29-2001 15:56:37
 Re: Re: Increasing torque on 8N in reply to raytasch, 11-29-2001 10:46:57
I have 14.9-24's on my 8N. 'bout the same O D as 10-28's but 1 1/2 times as wide. really impressive ..... Dell
