Drain/fill Rad. and block coolant ??
Ray Md.
12-01-2001 05:32:13
When you refill system at the Rad. and tractor has
a thermostat does some coolant enter block before
thermostat opens to protect the block or is the
block o.k. until thermo opens. Nothing in FO4.
Thanks !
Dell (WA)
12-01-2001 06:40:23
 Re: Drain/fill Rad. and block coolant ?? in reply to Ray Md., 12-01-2001 05:32:13
Ray..... ...all radiators are designed to "input" water to engine waterpump from the bottom of the radiator. This is a failsafe design. So your concern about filling radiator and engine blockage by thermostat, while understandable, is "not to worry"..... ...Dell
