Timing gear and front axle pivot pin
robert
04-15-2000 17:14:00
can the timing gear be removed without removing distributor gear?,also after removing one side of front axle to remove oil pan to fix oil leak i found worn bushing in front axle pivot can this be hammered out from the back side?,maybe heat with a torch?
Steve (IA)
04-16-2000 03:30:39
 Re: timing gear and front axle pivot pin in reply to robert, 04-15-2000 17:14:00
Don't know about the timing gear question, but the bushing can be driven out and replaced. Heat may help. My bushing was completely shot and I had to replace the pin also. Good luck
Steve (IA)
