Order Ford 8N Parts Online
8N starter drive is stuck
Paul
12-03-2001 10:42:30
I recently started work on an 8N that has been sitting for several years. I finally got the starter motor to spin, but the drive will not engage the ring gear. Anyone know of any tricks to loosen it up without splitting the tractor in two? Any suggestions would be greatly appreciated.
Bill Orono, MN
12-03-2001 14:07:01
 Re: 8N starter drive is stuck in reply to Paul, 12-03-2001 10:42:30
Pull out assembly, buy new starter drive (35-55 bucks, install assembly with new drive. Hook up wire and off you go. My experience is once you have problems with the starter drive it is best to throw it out.
Claus
12-03-2001 10:46:03
Remove the starter and try to work the drive free. Do not use any lubricant on the shaft and drive gear. Happy Motoring
Claus
