Order Ford 8N Parts Online
Is it or Isn't It a 8n
allen
12-05-2001 13:47:19
I have a 8n tractor or I thought with a 3 speed transmission and reverse. Everything I've been reading shows only 2n/9n with 3 speed and 8n with 4 speed. Is this correct? Did they make a 8n with 1,2,3,R?
allen
12-05-2001 14:21:50
 Re: Is it or Isn't It a 8n in reply to allen, 12-05-2001 13:47:19
yes the engine shows a 8n seriel # and with both brake pedals on the same side which is a 8n rearend. I must have a 2n/9n tranny and
After bush hogging for a few hours this weekend in first gear. I returned back to the shed in 2 gear. After placing the tractor in neutral or so I thought and letting out on the clutch the tractor is still in gear. I shifted the tractor into reverse but the tractor bogs down and does not move as if its in 2 gears at one time.Any advise on what to look for after I pull the top cover. I have never been into the tranny.
Johnny
12-05-2001 14:10:59
That sounds like a 9N/2N tranny. Check the Serial # on the engine to see if it starts with a 8N or 9N. I've got a 2N with a lot of 8N parts on it (ie: fenders, hood, front rims, ect) and a 8N paint job. A lot of these old tractors have been fixed up at some time or another with parts from a sister model.
ED-Illinois
12-05-2001 14:05:25
What made you think it was an 8N?
The 8N had a different transmission and modified hydraulic system than the 9/2N. The 8N had the 4 forward 1 reverse transmission and position/draft control selector lever.
However, since the engine was the same for all the Nseries tractors, you might have an 8N tractor and a 9/2N transmission.
allen
12-05-2001 14:23:49
 Re: Re: Is it or Isn't It a 8n in reply to ED-Illinois, 12-05-2001 14:05:25
