Differential leak located at the tailpipe accumulates a big oil spot on the floor when parked.
Phil
12-07-2001 08:32:07
I am experiencing a heavy trans or differential leak that puddles in the garage. It appears to be coming from just above the tailpipe area. How can this be repaired? Never had this before.
roperboy
12-07-2001 09:05:44
 Re: Differential leak located at the tailpipe accumulates a big oil spot on the floor when parked. in reply to Phil, 12-07-2001 08:32:07
hi phil, is it coming from the lift pin bracket? if it is, the gasket needs replaced. have to pull the axle housing on that side as the lift pin has a castellated nut on the inside. not too hard just heavy work.
Mark in Central Ohio
12-07-2001 09:00:31
I had a leak that gradually got worse in the area I envision yours is near. I kept cardboard under the tractor to keep the floor clean. When I replaced my muffler, I found that the nut holding tailpipe clamp was loose. After I tightened it up my leak stopped. Hope your's is a simple as mine was.
