Gas tank cleaner
Pat Woodruff
12-07-2001 16:25:08
What is the best way to clean out an old tank? It had about 3 gallons of varnish in it as it sat for the last few years. Should I use acetone or muratic acid? I'd like to get the rust out as well.
steve
08-28-2003 07:54:06
 Re: Gas tank cleaner in reply to Pat Woodruff, 12-07-2001 16:25:08
If rust isn't a problem and varnish is..... I took my carb cleaner and dumped it in the tank after draining the old gas. I let it sit for 2 or 3 days, drained it and rinsed it out. It works on carbs, it will work in tanks.
J52J
12-08-2001 02:42:14
I used the POR-15 about 3 yrs ago. Just like Old George said. Looks like porcelain. It really works well.
J52J/Jess
Old George
12-07-2001 22:51:11
Pat, POR-15 is the way to go. Mine was similar to yours with years of varnish and beginning to rust. Now the inside has a porcelain like finish. Click on the link below for more information. But don't believe me, check the archives. Hope this helps.
Alan Esch
45 2N kit 183513
andy
12-07-2001 18:29:47
Just got mine back from the radiator shop. they boiled it out, fixed a pin hole then sealed the insides with some special goo. cost about $50. Also check the archives, some guys have had good luck with another type of tank sealer. My understanding is if you don't seal them they will rust again and in a year or two you will be back to where you are now.
NCN in TX
12-07-2001 18:22:50
I had great success with a product for cleaning/derusting/re-lining gas tanks. Go to www.eastwoodcompany.com and look through their catalog. HTH.
Niels
Tom
12-08-2001 10:19:37
 Re: Re: Gas tank cleaner in reply to NCN in TX, 12-07-2001 18:22:50
Ditto on the gas tank cleaner I did it three years ago on a 9N and haven't had a fuel problem since. It takes a while to do it right but it's worth it in the long run.
Good luck
Tom
Tom
12-08-2001 10:19:26
Good luck
Tom
alan
12-07-2001 16:39:36
My 800 sat for about 5 years, I took off the gas tank and used this fuel tank repair kit to clean it and seal it. Worked great for me.
www.kanter.com/fueltank.html
