WHAT DO I HAVE
PEPPER WYSONG
12-09-2001 16:35:34
MY FIRST TRACTOR,#9N107834.NUMBER IS STAMPED ON THE SIDE JUST WHERE IT BELONGS.IT HAS I BEAM AXLE
RODS,AND A THREE SPEED TRANS,IT SHOULD BE A 1943
TRACTOR.ONLY PROBLEM IS IT HAS A SIDE DIST.WHAT
IN THE WORLD HAVE THEY DONE.
PEPPER
12-11-2001 12:02:57
 Re: Re: WHAT DO I HAVE in reply to Larry 8N75381, 12-10-2001 07:35:31
LARRY,
I FOUND A 8N TRACTOR TODAY AND LOOKED FOR THE NUMBERS THAT WERE IN THE PICTURE,THEY WERE JUST LIKE YOU SAID.ALSO I LOOKED AT THE DIST.MINE DOESNT LOOK ANYTHING LIKE THE 8N TRACTOR DIST.THE ONE I HAVE IS MASSIVE COMPAIRED TO THE 8N.IT LOOKS LIKE 2FORDSMIKE COULD BE RIGHT.THIS THING HAS A DIST.----- COULD OR DID THEY HAVE A KIT TO ADAPT A DIST. TO A MAG. MOUNT. MY DIGITAL CAMERA BROKE OR I WOULD SEND A PIX.I WILL TRY TO BORROW ONE.THE BOOK I HAVE DOESNT HAVE ANY MAG PIX SO IAM IN THE DARK.
MIKE,IF YOU READ THIS LET ME KNOW MORE ABOUT MAGS.
PEPPER
12-10-2001 20:58:17
THANKS LARRY
I GOT YOUR REPLY TONIGHT WHEN I GOT HOME.ITS ABOUT MIDNIGHT NOW AND I GOT OUT THE FLASHLIGHT AND MAG.GLASS.I FOUND A STAR AT THE FRONT AND ONE AT THE END.ALSO LOOKED FOR A CASTING NUMBER THAT WAS IN PHOTO,NOT THERE.IS THIS GOOD OR DO I STILL HAVE A MISTORY TRACTOR PEPPER
Salmoneye
12-10-2001 05:09:58
 Re: WHAT DO I HAVE in reply to PEPPER WYSONG, 12-09-2001 16:35:34
Sometimes when a motor needed to be replaced, the original serial number was stamped on the new block....
2fordsmike...could it be related to magneto?
12-10-2001 11:26:40
 Re: Re: WHAT DO I HAVE in reply to Salmoneye, 12-10-2001 05:09:58
Hey Salmoneye: Didn't some WW II 2Ns and most combine engines have a sidemount magneto? Could these be changed to distributor? Can any front mount distributor engine be converted to sidemount? Or, can the sidemount distributor be used only on a sidemount block that would have been made in the late 8N era? I've been wondering about all of this for a year or so. Thanks for expertise. Mike-Iowa
Jay 2NSC
12-09-2001 17:24:19
Evening Pepper,not to worry.What they have done is replaced the old front mount dist. with a newer side dist. from an 8N.It is a common fix for a worn out or blown up motor.You are correct it is a 1943 2N. :) Jay 2NSC
