Need Carb. parts/ for a Jubilee
oslofile in NC
12-10-2001 12:51:10
I took my carb apart and see that I need a couple of small parts that aren't included in the kit and the NH dealer doesn't carry them.
I have a Marvel Schebler STX428 carb. After tearing it down I found the spring on the air intake butterfly is broken. The black rubber washer that was on the throttle shaft should be replaced. This may be an add on part, in that it isn't shown on any drawings that I have seen. I also need the idle jet and a sand drain plug.
Also a question. On the top half of the carb. Looking into the throat that attaches to the manifold, about one half inch into and on the wall are two pin sized holes. the fartherest one is open and I see where that leads to, but the one closest to the manifold side just seems to be only about an eight of an inch deep. It doesn't seem to lead anywhere. Am I wrong?? If so what do I do next.
I hope this is clear. You can post me or email me with any info. Thanks in advance
oslo
