Sort of OT- Implement Diagrams
68 Mag
12-12-2001 12:55:02
third party image
Well, in my boredom, I designed an implement to rake leaves. I assume it would be large, bulky, and impractical in reality, but if I ever get the materials, I may try to build it just for fun. Here is a diagram I drew up, and I wanted to know if anyone thought this would work? I'm still working on some technical stuff, like gear ratios and how to put an activator clutch on it, so I could pull it without the header spinning, i.e. transport or hauling a load to dump. By the way, I forgot to put in the picture- The straight part on the rear is a door. There is a hinge right where it angles, and a latch at the bottom.
Old George
12-13-2001 12:44:57
 Re: Sort of OT- Implement Diagrams in reply to 68 Mag, 12-12-2001 12:55:02
68, you want to pick up leaves? Get you one of these.
third party image
You can pick up a ton of em in no time and you dont even have to get out of the seat to empty the hopper. Even has a drink holder for your favorite beverage.
68 Mag
12-13-2001 16:48:32
 Re: Re: Sort of OT- Implement Diagrams in reply to Old George, 12-13-2001 12:44:57
How much are those anyways, 2 or 3 thousand?
About four times that much actually...
12-13-2001 17:39:55
 Re: Re: Re: Sort of OT- Implement Diagrams in reply to 68 Mag, 12-13-2001 16:48:32
...but worth every penny of it as far as time saved. Easy to maintain also.
Alan
68 Mag- Figures...
12-13-2001 18:21:18
 Re: Re: Re: Re: Sort of OT- Implement Diagrams in reply to About four times that much actually..., 12-13-2001 17:39:55
...But I'd rather use an N or Farmall with finish mower...more fun that way. =)
Johnny
12-13-2001 07:43:26
If you so many leaves you need an implement, I have a better idea. Using your tractor and a hay rake, rake them into rows, bale them with a square baler. Take the leaf bales to the nearest big town and sell them as compost.
Andy
12-12-2001 19:56:23
Ifn I were doin' it I'd use a pto drive for the rake, the have it throw the leaves into a tilt bed trailer. That gives you a clutch for the rake and an easy dump for the trash.
68 Mag
12-13-2001 08:03:10
 Re: Re: Sort of OT- Implement Diagrams in reply to Andy, 12-12-2001 19:56:23
I would do that, but I'm designing it to be pulled with a 20 horse riding mower, without a PTO.
kevin
12-12-2001 14:04:39
68
Not to be facetious, but they already make these. I have one on my lawn tractor.
-kb
68 Mag
12-12-2001 14:38:41
 Re: Re: Sort of OT- Implement Diagrams in reply to kevin, 12-12-2001 14:04:39
Oh well. I guess I'll just build it anyways. :)
kevin
12-12-2001 17:41:34
 Re: Re: Re: Sort of OT- Implement Diagrams in reply to 68 Mag, 12-12-2001 14:38:41
There you go!:)
kEN n tX
12-12-2001 13:36:17
THE WAY I SEE IT, THE SWEEPER WOULD BRUSH THE LEAVES UNDER THE TRAILER NOT IN IT!
Rusty 2N
12-13-2001 04:56:52
 Re: Re: Sort of OT- Implement Diagrams in reply to kEN n tX, 12-12-2001 13:36:17
I was gonna say it needs a feeder chain & throat like on the combines.
