Order Ford 8N Parts Online
Meyers 6' Jeep snow plow on an 8N, Picture
Norman
12-13-2001 22:43:46
third party image
I felt you guys would appreciate seeing my most recent project. It is a dream to use. Correct weight, etc. Front end doesn't travel when plowing to side with the small tri-rib tires.
No extra weight needed on the rear with loaded tires and tire chains. This rig is a bull dozer.
Dave Smit, Another good reason
12-14-2001 12:52:02
 Re: Meyers 6' Jeep snow plow on an 8N, Picture in reply to Norman, 12-13-2001 22:43:46
Hi Norman, That is another good reason to convert to 12 volt. Nice neat looking job. It looks like you have a cut out in the hood above the battery what is that for?
Dave <*)))><
Norman
12-14-2001 19:15:27
 Re: Re: Meyers 6' Jeep snow plow on an 8N, Picture in reply to Dave Smit, Another good reason, 12-14-2001 12:52:02
Some Idiot, former owner of this 8N, made a cut out to more easily remove the battery. Can you believe it?! All one need do is tilt the battery down a bit, and wallah, its out. Maybe he smoked a bit too much whacky terbacky.
I was wondering who would be observant enough to notice this. I may be repairing this, or even replacing the hood.
Good tractoring to all this holiday season.
Fessman
12-16-2001 17:56:55
 Re: Re: Re: Meyers 6' Jeep snow plow on an 8N, Picture in reply to Norman, 12-14-2001 19:15:27
Norman,
I have the same cut out from a previous owner. The owners must have been related.
Fessman
Dave Smith
12-14-2001 19:53:03
Did he cut the inner frame also? If the hood is not rusted too bad over the dog leg a piece could be formed and mig welded in. Too bad some one does not make patch pannels for the molded section. I tried to form one using a epoxi mold but I could not get the center crease sharp enough. Would have to use a rolling mill. I ended up using fiberglass cloth and bondo to patch the rusted area on mine. Turned out pritty good.
Dave <*)))><
Bruce
12-14-2001 07:21:35
It looks G-R-E-A-T !!! Any chance of getting some pics showing the details of how you mounted it?
Norman
12-14-2001 11:47:50
 Re: Re: Meyers 6' Jeep snow plow on an 8N, Picture in reply to Bruce, 12-14-2001 07:21:35
I hope to get some other photo's of details on the mounting and wireing on the net somewhere so you can see them. I have signed up for onebigvillage.com, and have to get the pics on there. I will notify this forum when I get this done.
Claus
12-14-2001 04:48:11
Beautiful job... It all looks professional. Even has a hydraulic cylinder for angling the blade. Happy Motoring
Claus
