SHERMAN HI-LO
PHIL GA.
12-16-2001 08:41:35
I NEED BEARINGS FOR A SHERMAN TRANS. ARE THEY STILL AVAILABLE? IF SO WHERE? THANK YOU FOR ANY HELP YOU CAN GIVE.
KCM
12-16-2001 20:10:14
 Re: SHERMAN HI-LO in reply to PHIL GA., 12-16-2001 08:41:35
Look for any part numbers on the bearings. Most likely they were not unique to the Sherman (probably made by BSA or some other bearing company) and can be purchased or cross referenced to an equivalent at a shop that specializes in bearings. Take the bearing with you to match it up.
