What have I done? ORC/cotter pin hole
Russ(NM)
04-17-2000 19:43:29
I had my ORC off for a while for use with other implements, but put it back on to use the bush hog. I failed to tap the roll pin in far enough, and quickly figured it out when I tried to stop before hitting a fence. Since I had only about 15 minutes of mowing to do, I left it that way and proceeded very carefully with the mowing.
As I was unhooking the mower, I noticed fluid dripping from the little hole under the transmission that has the cotter pin hanging in it. This has not happened before.
Would the momentum from a spinning bush hog somehow affect seals or whatever along the drive train and allow fluid to leak out? Have I really messed something up?
Claus
04-18-2000 08:20:04
 Re: What have I done? ORC/cotter pin hole in reply to Russ(NM), 04-17-2000 19:43:29
Naw.....Just a conincidence...
Happy Motoring
Claus
