Order Ford 9N Parts Online
9N PINION GEAR
SHAWN GORDON
12-20-2001 17:21:18
Im restoring a 40 9n and the pinion gear is pretty well trashed. I know that the ring and pinion should be replaced as a mached set. But the IT book said that it is not nessasary to do so, what do you all think? It looks like a lot of work to change booth.
Thanks Shawn
Gaspump
12-20-2001 18:44:40
 Re: 9N PINION GEAR in reply to SHAWN GORDON, 12-20-2001 17:21:18
If you are replacing with new gears yes they should be a matched set. If you are replacing both of the gears with used it is preferable to replace them with a used matched set. If replacing only one gear with a used gear, that is OK. The worst case scenario with used unmatched gears is the possibility of a slight gear noise. By the way the 2-8-9N pinion is more than likely to be the damaged gear, happens on a great percentage of N's.
