Advantages of the small deisel
3 cyl Kabuto Di
12-21-2001 13:29:18
can some one make a few comments about the 3 cyl diesel,is it a long lasting engine and worth the extra money and is the maint a problem or easy,,,Thanks Guys...its in a small cub cadet tractor and those guys don't seem to know much about them on the cadet board...Leave it to the N'ers to get the straight scoop
Stuart K
12-22-2001 15:14:05
 Re: advantages of the small deisel in reply to 3 cyl Kabuto Diesel, 12-21-2001 13:29:18
Two of my neighbours have Kubota 3 cyl diesel mini tractors. They swear by them. I can't speak for their longevity however. I used one fellows because it had a front end loader. It worked very well but I found tractor quite twisty with a load in the bucket. I think they are a little jealous of my 8N though ;^) ( another neighbour has a 48 N with a loader that I'm jealous of!) Others mentioned high mortality in the field but diesels IMO should get more oil changes if you want them to last the way they should, so there is some truth to the poor maintenence issue. tuK
ron g
12-22-2001 05:15:36
got a small fleet of em,the amimals that runnem, startem cold- then up to max rpm. thats life fellas, 14 horse to 50 horse- some new some old. bout every 2500 hours drop injectors out, bout every 100 change oil, etc. 25% fail rate-thats on you, them thing live in skid loaders too, stump grinders, all sorts of eq.
the only one i had apart---- hahaha outa of 25 machines- that still run and never had apart, was a used machine that was purcased. had burnt pistons-- been overheated, lots! bad themostat was the cause. abuse anything it will fail. ron
Sal
12-21-2001 16:46:34
My cousin and I were just talking about the 3 cyl. Kabuto diesel engines last week...he now works in a new division of his company and this is the engine they use to run refrigerant compressors in their products. Overall he is not too impressed. They are seeing almost a 25% rate of failure or serious problem in the field within the first three years on them. Kabuto says they are improving the product all the time and that the numbers are high because the engines are not properly maintained in the field. I am sure there is some truth to the mantenance part...but that seems like a horrid number of problems. Personally I wouldn't buy anything with one of these engines in it.
ED-Illinois
12-21-2001 14:27:04
Someone on this board posted a story once that went like this.
While looking at a new Kubota to replace an old 9N, a salesman told the interested buyer that the tractor cost in excess of $18,000. Seeing his shock at the cost of the new import, the salesman explained that the Kubota was a 30 year tractor, implying it would last 30 years. Funny advice to a man who was using a 50+ year old Ford Tractor.
just the Kubota Diesel
12-21-2001 15:07:38
 Re: Re: advantages of the small deisel in reply to ED-Illinois, 12-21-2001 14:27:04
Thanks Ed, but i waas refering just to the diesel, I under stand they use them on sail boats cub cadet tractors generatores etc, I have to chance to get one at a cheep price, was hopeing to get some input on the life of it, cost of reapir main etc, like I say the guys over on he cadet board aren't tat familuar with them I don't think....Thanks agin
68 Mag
12-21-2001 15:10:52
 Re: Re: Re: advantages of the small deisel in reply to just the Kubota Diesel, 12-21-2001 15:07:38
Well, while I have no direct experience with them, my uncle's father in law has a Kubota diesel tractor, and I know it's at least 10-15 years old, if that helps.
