Building a rear trencher, any ideas?
Paul8N
12-21-2001 16:32:02
Just finished fabing my 3pt. trailer hitch. As I was admirring it I thought with a little help from you all we could come up with a trencher. Was thinking along the lines of the hitch but with an I-beam held vertically and adjustable into the soil that with a few passes could make a trench. WHat ya think. thanks in advance, Paul
PAUL8N
12-21-2001 19:41:44
 Re: Building a rear trencher, any ideas? in reply to Paul8N, 12-21-2001 16:32:02
Thanks Dave(MI), I sent you an e-mail about it. Thanks for the input.
Paul
Dave(MI)
12-21-2001 19:28:54
Hey Paul, Look in the implement photos archives. A while back, I loaded a picture of an item I got with my tractor when I bought it.
It is called a Wills Ditcher, and that is the name the photo is under. It attaches by the 3pt and then it looks like it would use a couple of cylinders to operate.
If you can not find it, let me know and I will try and post the photos again.
I have not done a thing with it since I got it and I was thinking about selling it but I could not find any other info on it.
I do not know if the hydralics on an N would run it or not. I do not have any cylinders to try it.
Dave(MI)
swavo
12-21-2001 18:43:29
try running a few passes with a single bottom plow
Jerry WI
12-21-2001 18:21:07
Paul8N,
In the archives there is an article about a guy trenching with a plow. I've listed the link below. Hopes this helps. Happy Holidays
Mikey
12-21-2001 17:31:48
Paul,
ten years ago I needed to run temp water lines for 1000 seedlings I had put in. I don't know if it will go deep enough for you, but what I made was cheap and worked well.
TSC had some "V" plow blades about 18" wide and 24" tall. I fab'd two mounting plates out of flat stock and attatched one to the V plow and one to the bottom of my back blade I beam. 4 bolts held the two flat plates together when it was mounted. When I wanted to trench, I bolted the v plow on and dug away. If depth wasn't a concern (16+"), I left the back blade on for more digging weight. If I needed to go deeper, I removed the blade completely. If I needed the back blade, I removed the four bolts and the back blade would still swivel freely under the fixed mounting plate.
If I had a pic, I'd post it. It worked well, and parts were about 25 bucks.
mikey
Paul8n
12-21-2001 17:00:45
Would like an easy way to dig a trench for footing of the garage I am going to build along with trenches for water drainage hoses off of downspouts and underground electric and gas. Thanks again for your input.
Dave Smith
12-21-2001 16:56:33
Paul, What are you trying to do. If you are trying to dig a drainage ditch you have to get rid of the dirt. If you are trying to bury a cable or plastic water line a sub soiler works good. Dave <*)))><
