It is a '47 2N with a 12V conversion, standard front mount distributor. I hope ignition timing adjustment would do the trick, since I had to go in there and adjust the points that kinda makes sense. The IT manual is kind of sparse as far as description of how this is done. Could someone give me an idea of proper procedure? In the manual they desribe a straight edge and aligning with the mounting holes - which seems clear from the figures, but then they mention the adjustment "plate" on the side. I'm guessing that they are referring to what looks like a rectangular flat piece on the side held on by a bolt, and fitted into a "slot" in the casting. My question would be how does this move/adjust if this is what they are referring to?? Obviously the straight edge adjustment is done "not running", but is the other adjustment done "running" (seems a bit dangerous) or adjust, start, try, stop, adjust, start, try again....???? AndyB
