How much weight can the hydraulic system lift?
patrick md. va.
12-24-2001 06:52:34
I have a '44 2n that seems to lift well ,but how many pounds should they be able to lift? I have a disc that is about 6 ft and has 4 rows of disks. It can lift it but the front gets very light! I also have a 3 point crane and i can lift a 4 foot tall by 4.5 foot round of an oak tree. This seems good to me! Have a merry christmas everyone. My small site is www.erols.com/hpmt
patrick md. va.
12-24-2001 19:33:31
 Re: how much weight can the hydraulic system lift? in reply to patrick md. va., 12-24-2001 06:52:34
Sorry but you all know how hard it is to post pics on hear. Till i have time to mess with it i will give you the address of the pic that i tried to post. www.erols.com/hpmt/log3.jpg
patrickMd. va.
12-24-2001 19:17:44
I will try to post a pic of one of the oak rounds that i lifted with my crane. I do have 19 by 4 inch tires and no weights. Thanks for all the info.
Mark Hendershot
12-24-2001 18:44:07
Well I tested my hydralics to day! I put my aprox. 350lb+ snow blade up against a 8N front end with frontwheel weights on the 8N tied it on lifted it and my front end just floated till I backed it up then it would go down. I did get it in the garage but my front tires were light. Don't know how much I was lifting but the hydralics on my Ferguson TO-30 worked fine! Mark H.
That oak is 2900#!
12-24-2001 09:08:12
That's if its density is 45#/cu.ft.
snitkawl
12-24-2001 15:47:31
 Re: Re: how much weight can the hydraulic system lift? in reply to That oak is 2900#!, 12-24-2001 09:08:12
If I read his post correctly, I don`t understand how you came up with your 2900# figure. Four ft long x 4.5 ft round would be about 18 inches in diameter which would yield less than 100bd ft. I use 5# to the bd ft as a rough figure. Maybe I am misunderstanding, and it is 4.5 ft across? That would be pretty huge for an oak around here, but not impossible.
Pfft! 290# that way. nm
12-24-2001 16:41:23
 Re: Re: Re: how much weight can the hydraulic system lift? in reply to snitkawl, 12-24-2001 15:47:31
x
PJ Niner
12-24-2001 08:01:09
Patrick,
I have several hill behind me and mine will lift enough to make me wet my pants if I try to come up with too much firewood in my work box. :) So take it easy..... . PJ Niner
Dave 2N
12-24-2001 16:05:33
 Re: Re: how much weight can the hydraulic system lift? in reply to PJ Niner, 12-24-2001 08:01:09
You got that right! Even a rear scoop bucket with gravel makes my 2N into a "twinkletoes."
Ultradog MN
12-24-2001 07:23:17
Dell just was talking about that a day or two ago
