Trying to post pic from the earlier post of how much can i lift.
Patrick md. va.
12-25-2001 04:24:03
third party image
This is one of the peices of oak that i moved. Hope it shows up. Patrick
goinNutts
12-25-2001 19:52:40
 Re: Trying to post pic from the earlier post of how much can i lift. in reply to Patrick md. va., 12-25-2001 04:24:03
so whatcha gonna do with that nice piece of wood???? looks lioke it may make nice table material ,
Pat
patrick md. va.
12-25-2001 20:13:44
 Re: Re: Trying to post pic from the earlier post of how much can i lift. in reply to goinNutts, 12-25-2001 19:52:40
We have a place on the river in Va. There is a 65 foot sand bank down to the river. when there is a fall it takes the trees too. In an attempt to keep the wood we had a man cut down the tree with one of those machines that can grab the tree while they cut it free and lie it on the ground. From there it was my job to cut it all up and split it for fire wood. I did save the biggest round of wood and put it in the rear of our very old and tired astro van. Now it can get the traction the it needs to pull the boat trailer up out of the all sand boat ramp. (Big stupid smile here) The van is only used on the place and very rarely goes anywhere but to the boat ramp. If you look at my site and go to the tractor page you can see the bank and the river.
Rob
12-25-2001 05:55:15
That be heavy ok! Those round bales people are dragging around can't weight as much as that round.
How do you keep the front wheels on the ground?
tom
12-25-2001 10:11:58
 Re: Re: Trying to post pic from the earlier post of how much can i lift. in reply to Rob, 12-25-2001 05:55:15
Round bales can weigh up to 2500 pounds or more, depending on hay type and size. We had some on the farm that were made with silage. They were VERY wet, and then wrapped in plastic and sat outside. We had a scale on the front loader, and some of them would weigh as much as 2700 lbs each. We didn't use an 8n though to lift them. Used a 6207 Deutz tractor with a front loader. Picked up a granite rock with it once that lifted the rear wheels, which were 2/3s full of calcium. That was a heavy rock. Sits in my front yard now, along with some others I've found.
uh . . . Dell (WA)
12-25-2001 09:58:18
Rob..... ..from New Holland 1991 round baler specs: 48d X 48L 650 lbs, 48d X 60L 1000 lbs, 48d X 72L 1500 lbs, 60d X 72L 2000 lbs.
Most N-Tractor hydraulics can't handle 'em cuz they can't keep the front wheels onnna the ground after about 750 lbs, neglecting the extended center of gravity effect caused by the bale spear which probably will cause the wheels to lift at 500 lbs..... .Dell, the self-appointed safety preacher who sez: wheelies are too exciting except on dragsters
Rob
12-25-2001 11:41:13
 Re: Re: Re: Trying to post pic from the earlier post of how much can i lift. in reply to uh . . . Dell (WA), 12-25-2001 09:58:18
I can too easily pop a wheelie with my heavy 5' rotary mower raised up on my 2N. I don't like it when that happens.
patrick md. va
12-25-2001 06:06:51
I do not have weights, and i have 19 by 4 inch front tires.
