Steering question
Order Ford 9N Parts Online
Ford 9N
Ross Mallatt
12-26-2001 06:25:25
My Ford 9N tractor isn't steering right. It pulls to the right and I have to hold tight to the steering wheel in order to drive straight. Any idea how to fix this?
Dave Smith
12-26-2001 08:18:51
 Re: Steering question - Ford 9N in reply to Ross Mallatt, 12-26-2001 06:25:25
Could also be a bad or over tight wheel bearing.
Dave <*)))><
bj/8N/mt
12-26-2001 08:13:07
Probably a silly thought but I will pass it on. Your front tires are approximately the same circumference; width; and air pressure aren't they? You might also want to jack it up to take all of the weight off the front end and make sure your steering gear doesn't bind on full turns.
YOur mileage may vary
Tyler (MD)
12-26-2001 07:36:43
Stupid question but is the tire pressure ok/same with both front tires?
Tyman
Rusty 2N
12-26-2001 06:47:16
Check your toe-in.
Claus
12-26-2001 06:46:39
Check you toe-in. It is probably not correct. You can measure this with a tape measure. The front of the tires should be about 1/8 - 1/4 in less than the rear of the tire. (Measure the front wheels at 3 and 9 o clock.)
Happy Motoring
Claus
Dave-NJ
12-26-2001 06:39:35
Sounds like you might have a brake hung up. Jack it up and see if your right rear wheel turns free.
jim
12-26-2001 09:18:43
 Re: Re: Steering question - Ford 9N in reply to Dave-NJ, 12-26-2001 06:39:35
Quit complaining or we'll nail your left foot down as well !
