Brakes
rj
01-01-2002 18:21:37
after taking the wheel off ,how do i get to the brakes on a 2n(1946)? the pedal sticks and wont return on both sides . the manual i have is for a 8n and doesnt show the breakdown. i think i can loosen everthing up with some wd40.if i can get to it.
roperboy
01-01-2002 19:05:47
 Re: brakes in reply to rj, 01-01-2002 18:21:37
hi rj, unbolt from the axle housing (6 nuts) and pull the drum and axle out as one unit. once you have it out then pull off the brake backing plate. you'll see once you get it out. good luck
