Well I just looked at my reply and it looks OK. HUummmmm. Take what you can get! :-) My frustration was partly because I started at 10:30AM and didn't get done (quit I mean) until almost 6:00PM. Had two (long) calls from someone needing printer help plus lunch. Spent the last hour getting no where, that is the way it goes sometimes. I also forgot to add that I like to keep the reduced image about 1 to 1.5 inches in size at 75 pixels per inch. I am used to trying to help and usually can give fair instructions for someone to follow, step by step. I hope that having the html code already "spelled out" with the place to substitute information specific to the situation, will make it easier for the guys brave enough to try the "fancy stuff" but a little unsure. Heck! I even use "canned" code as much as I can. I do html about once every two months, not enough to keep the CRS brain cells from having data drop out. :-) Unfortunately, using the "Optional Image URL:" box below the reply Comments: area will not allow the linking to a reduced image. That is why to do it you have to put the html code inside the Comments: box. SO, Rob's request to keep the image sizes down when you use the "Optional Image URL:" box is a good one.
