Removing Rear Axle Seals on a 2N
Rochester (WA)
01-06-2002 16:47:22
Is there a (relatively) easy way to remove the rear axle bearings on a 44' 2N so as to replace my leaking outer axle seals? All the bearing pullers I'm familiar with will not work with this absurd design. Who in their right mind would design an axle and put the seals behind pressed on bearings? I can see why Ford switched this setup when they went to the 8N models.
Old George
01-06-2002 17:38:28
 Re: Removing Rear Axle Seals on a 2N in reply to Rochester (WA), 01-06-2002 16:47:22
Are you sure it is the outer seals that are leaking and not just the gasket/shim interface on each side of the brake backing plate? Most leaks are a result of problems there. If it is the outer seals but your bearings are in good shape I would just use sure seals. Or you could try Dr. Zane's unconventional method as at the link below. Hope this helps.
Alan Esch
45 2N kit 183513
