Gas spill on starter motor
how soon is it safe to start up
Peter
01-06-2002 17:45:28
Yesterday I replaced the valve under the fuel tank after draining the tank. I found out that there is about a pint of gas which does not come out until you remove the valve. At that point it comes out all over everything, and gives the starter motor a good drenching. I don't want to take that apart to check. I just want to wait long enough so that any gas which got in has evaporated. The temperature may have a bearing on the time factor. It is running about 30 degrees. The tractor is in a well ventilated barn.
How soon is it going to be safe to start up?
Dell (WA)
01-06-2002 17:53:00
 Re: gas spill on starter motor - how soon is it safe to start up in reply to Peter, 01-06-2002 17:45:28
Peter..... ...Wait until ya can't smell gas enny more, probably wait until tomorrow to be safe..... ...Dell
