Bearing Retainer Gasket
Ole WI
01-07-2002 10:58:09
Reviewing the FO4 and Master Parts manuals, the clutch side bearing retainers for the transmission mainshaft and the countershaft for my 49 8N are installed each with a fiber(paper) gasket. Since my tractor is already split for a new clutch and mainshaft seal, should I also replace these $0.30 gaskets? I think the mainshaft retainer gasket should be a piece of cake but I am not sure about the countershaft retainer. Can I just remove the 4 bolts holding this retainer on and renew the gasket or will the countershaft fall and prevent me from reinstalling the retainer? I recall lots of discussions centering around the mainshaft seal but I found nothing on the retainer gaskets. Any insight would be helpfull.
Thanks
Ken in PA
01-07-2002 18:42:54
 Re: Bearing Retainer Gasket in reply to Ole WI, 01-07-2002 10:58:09
Well since you suggested it and my motors out, I guess I better plan on that too. I do have a little gunk in the bellhousing! Please E-mail me if everything falls apart or works good.
Thanks,
Ken
Dell (WA)
01-07-2002 11:58:33
Ole..... ..its generally a good practice anytime you disturb a gasket to replace it. Prevents callbacks. 'course if'n ypu are your own warrentee station, whats it worth to you to not haffta go back and redo it? 30 cents, bettcha its worth it to me..... ..Dell
Ole WI
01-07-2002 12:56:50
 Re: Re: Bearing Retainer Gasket in reply to Dell (WA), 01-07-2002 11:58:33
Dell.....thanks for the insight. My thoughts also! I have ordered a new retainer gasket for the mainshaft. Still don't know about the countershaft retainer. Not sure if this a possible source of leaking due to the massive amounts of gunk I had to deal with. Have you ever heard of fluid leaks from the bearing retainers? If I pull the countershaft retainer, will the countershaft drop preventing me from reinstalling the retainer? Thanks for your help.
Ole WI
roperboy
01-07-2002 13:37:19
 Re: Re: Re: Bearing Retainer Gasket in reply to Ole WI, 01-07-2002 12:56:50
hi ole, yes the countershaft will fall. if i remember right when i did mine i picked up on the main shaft gears and reinstalled the gasket and cover. it wasnt much of a problem or i would remember it well. mine was leaking there a little bit also. good luck
