Ring pinion gears
patrick md. va.
01-07-2002 14:13:40
My '44 2n has not had the fluid changed in the rear part of the tractor in at least 15 year. The fluid is a bright gold color and never needs topping off. All the posts talking about changing the fluid and removing all the crud have me worried about what i may find when i go into clean it out! I want to know if the n tractors have a problem wearing out the ring and pinion gears? I have gotted this idea from reading the posts. Is it so? My tactor is in good shape and everything works great now. It has always been under a roof, so no water is in the trans. It has worked a long life because it has had 3 motor rebuilds. Thanks.
try this
05-23-2003 14:48:29
 Re: Ring pinion gears in reply to patrick md. va., 01-07-2002 14:13:40
third party image
Gordy MN
01-08-2002 10:03:06
Patrick I have read posts about the pinion gears also. I don't think it is a problem unless you notice a problem while working tractor. I rememeber a post a few months ago and most people were not concerned about a small chip out of a pinion or ring gear (be sure to remove chip however). I am in the process of replacing my rear center housing. I was amazed at the crud that was in my 8N housing. In three years I had replaced fluid three times and even ran it for a half hour with diesel fuel to clean things out. It is stored inside, but for some reason I could not get water out. Maybe it was condensation. I will clean out transmission housing as best I can. I hope that will take care of water problem. Gordy MN
patrick md. va.
01-08-2002 13:47:35
 Re: Re: Ring pinion gears in reply to Gordy MN, 01-08-2002 10:03:06
Thanks for the info. I will let you know what i find.
I have asked a freind to fix the background tonight.
01-07-2002 18:59:09
 Re: Re: Re: Ring pinion gears in reply to Tÿlër (MÐ), 01-07-2002 17:19:26
I found your nicely done background way before i started to read this board and did not see any harm. I have made a background that i do not like but i will have to deal with till i can go take better pics.
Tÿlër (MÐ)
01-08-2002 02:38:53
 Re: Re: Re: Re: Ring pinion gears in reply to I have asked a freind to fix the background tonight., 01-07-2002 18:59:09
No harm, use it if you'd like. I'm honored. It's always good to ask before borrowing.
Thanks,
Tyman
Bingo........Hold your cards
01-07-2002 17:22:12
I knew I'd seen it before !
ROFL
Later"Belch"dave
JerryU
01-08-2002 04:00:13
 Re: Re: Re: Re: Ring pinion gears in reply to Bingo........Hold your cards, 01-07-2002 17:22:12
And once a year dave#1 gives Tyman lessons on how to drive a working tractor.
JU
