Still here, and asking questions...
68 Mag
01-10-2002 17:44:40
...About tire pressure. What is the correct pressure for un-filled, un- weighted, 4 ply rear tires? Mine are at 26 psi, but from what I've read, that seems kind of high.
68 Mag
EDDIE8N
01-10-2002 18:15:34
 Re: Still here, and asking questions... in reply to 68 Mag, 01-10-2002 17:44:40
68 mag,
Unless you like to "ride high in the saddle", you better let some air out of your tires.
Should be about 12psi.
Click on the link below, then click on 8N SPECIFICATIONS and DATA.
Remember to bookmark the page for future reference, lotta good info there.
bjt
01-10-2002 18:09:35
Hey 68 Mag!
I keep mine at 20 but that's just because one of them won't hold air for more than 4 days..... The tire sidewall should have a maximum pressure rating on it somewhere, but it may be really small and hard to read. I think my mis-matched Firestone/GoodYear combo are reated for about 15 psi.
What did you decide about that Lincon?
bjt
68 Mag
01-10-2002 18:12:47
 Re: Re: Still here, and asking questions... in reply to bjt, 01-10-2002 18:09:35
Well, I'll look at the tires tommorrow. The Licoln...well, we still havent decided. It'll either set and rot away, or we'll attempt to restore it...but it wont be parted out.
bjt
01-10-2002 18:31:07
 Re: Re: Re: Still here, and asking questions... in reply to 68 Mag, 01-10-2002 18:12:47
Fair enough.
I would still recommend that you take a look at the rear end. If it's got disc brakes, it's worth your time and effort to remove it and store it somewhere out of the elements. It really is a valuable assembly (axles, third member, housing, hubs, brakes) that you may well wish you had someday.
bjt
Bill Clinton
01-10-2002 19:18:03
 Re: Re: Re: Re: Still here, and asking questions... in reply to bjt, 01-10-2002 18:31:07
Also missed initial post. record 1 - 9n located in Livonia, New York
lock up your daughters and wives men, Clinton is loose on the N Board!
01-10-2002 20:56:40
 Re: Re: Re: Re: Re: Still here, and asking questions... in reply to Bill Clinton, 01-10-2002 19:18:03
no message
alan
01-10-2002 20:19:42
President Clinton?
I also live in Livonia, NY..... .....1-8n and 1 841.
