Brian in S. Ill 12 volt conversion diagram
Ringy
01-14-2002 09:34:21
I've been seaching the achives and this web page (http://scribers.midwest.net/briabeck/conversion) keeps getting rave reviews. I can't get in anymore as the link looks to be about 2 years old. Anyone have an updated like or a copy of this diagram ?
Brian *N* S. IL
01-14-2002 23:30:05
 Re: Brian in S. Ill 12 volt conversion diagram in reply to Ringy, 01-14-2002 09:34:21
Ringy,
Here's the new address to my webpage:
Link
Dave Smith
01-14-2002 14:10:42
Instead of using the marker lamp use a diode. I bought a diode pack from a local tractor repair shop for $8.50. It has the male and female plugs and plugs right into the alternator. The old plug goes into the other end. Ace part #S3300. Makes a neater job.
Dave <*)))><
Danny in CO
01-14-2002 10:19:36
 Re: Re: Brian in S. Ill 12 volt conversion diagram in reply to Danny in CO, 01-14-2002 10:05:12
Also, here is a wiring diagram for 12 volt conversion for side mount from NSeries.com:
third party image
Danny
Ringy
01-14-2002 11:26:19
 Re: Re: Re: Brian in S. Ill 12 volt conversion diagram in reply to Danny in CO, 01-14-2002 10:19:36
Thanks, looks great, but I have a front mounted 12 volt coil. What canges do I need to make to this diagram for that coil?
Danny in CO
01-14-2002 11:54:39
 Re: Re: Re: Re: Brian in S. Ill 12 volt conversion diagram in reply to Ringy, 01-14-2002 11:26:19
I would use the first diagram for a front mount distributor. With a 12 volt coil, you will still need a resistor to drop the voltage. I'm not sure what the resistance should be, but the voltage at the coil with the points closed should be about 7 volts (I think). Claus or Dell are better resources when it comes to the resistors.
Danny
