Fuel Flow Valve Question
Ron in Ohio
01-15-2002 15:41:50
I have a 46 2N and want to know if 2 turns open of the sediment bulb valve is the usual setting for fuel flow to the carburetor for normal operation. Also, the manual talks about a "reserve" setting for the valve. Does this mean fully open for this valve? Thanks for any info you provide.
Rob
01-15-2002 15:50:31
 Re: Fuel Flow Valve Question in reply to Ron in Ohio, 01-15-2002 15:41:50
Yes and yes. The book says to flush the stuff and water out of the bottom of the tank every 100 hours. You may wanna open the valve full open for a sec when you clean the sediment bowl.
