Front Axle Support Pin
Pat Williams
04-24-2000 06:21:24
The front axle support pin and bushing are shot on my '54 NAA. No problem getting a new bushing and pin but the hole in the axle has become egg shaped - not really bad but certainly out of round. What would be the best plan of attack here?
Claus
04-24-2000 06:29:54
 Re: Front Axle Support Pin in reply to Pat Williams, 04-24-2000 06:21:24
You could take the center axle to a good machine shop and they could weld and rebore for the bushing. Another option would be to look for a good center axle in a bone yard.
Happy Motoring
Claus
llamas
04-24-2000 07:23:37
 Re: Re: Front Axle Support Pin in reply to Claus, 04-24-2000 06:29:54
I've tried the bore-and-bushing cure on a 9N front axle. Problem was, the constant rubbing and impact had made the surface of the bore as hard as a taxman's heart - I just couldn't get it to cut, even with a carbide tool - it would jump and jitter around on the surface. This might work well if you have access to an ID grinder.
llater,
llamas
Fred
04-24-2000 14:25:57
 Re: Re: Re: Front Axle Support Pin in reply to llamas, 04-24-2000 07:23:37
Llamas, sounds like it has work hardened and needs annealed. Just heat it up red hot and let it cool real slow (in a bucket of lime or sand) and it'll cut then, probably with high speed tools. Shouldn't hurt a thing and solves a meanie. I've got to do the bushing thing to one of mine too. Thanks for reminding me to check mine with a file before I go to the trouble of setting it up in machine. Fred
llamas
04-24-2000 16:57:04
 Re: Re: Re: Re: Front Axle Support Pin in reply to Fred, 04-24-2000 14:25:57
Yeah, coulda done that. But I'm thinking it's a forging, and I didn't care to have the middle be so soft and the ends so hard - relatively speaking. So I got a boneyard piece for $25 and called it good. By the time I'd made a bushing and welded it in and cleaned it up, it wasn't worth my time.
But if there's no alterantive, annealing it would work. I think I'd be inclined to heat just the bore real hot, then let it cool by transmission out through the rest of the forging - keep the heat-affected zone to a minimum.
llater,
llamas
Michael Az.
04-24-2000 11:32:40
llamas, wonder what would happen if you tried to anneal the axle?
Claus
04-24-2000 08:08:36
How many Rockwell is the taxman's heart?
Happy Motoring
Claus
Fred
04-24-2000 14:28:20
 Re: Re: Re: Re: Front Axle Support Pin in reply to Claus, 04-24-2000 08:08:36
I'd guess it to be off the C scale and into D.
