Dual rear wheels
Randy Merry
04-24-2000 07:06:54
Has anyone installed dual rear rims and tires on a 8N? Would you share your method of doing this with me? I have a '49 8N and operate it on some hilly land, duals will really help me out. Thanks
huck
04-24-2000 13:17:04
 Re: dual rear wheels in reply to Randy Merry, 04-24-2000 07:06:54
at your local tractor dealer they should have studs w/threaded heads you bolt the first center on w/these then you reverse the other center & thread your old lug nuts into the studs.they also make an adapter plate set up also.i've used both w/good results. good luck
