3 point won't lift high enough!
Robert
04-24-2000 07:07:07
The 3 point will only lift all the way up if I remove the outer plate of the Quadrant and move the lever beyond the vertical position, works fine. Yes I have adjusted the Quadrant backwards all the way ,but its still only lifts 6" off the ground. Any ideas of the problem?
Phil
04-24-2000 14:04:01
 Re: 3 point won't lift high enough! in reply to Robert, 04-24-2000 07:07:07
Probably the cam on the other side of the plate from the lift lever is worn. Unbolt and pull plate and cam out. May need to weld onto cam to build it back up where it has gotten flat.
Robert
04-24-2000 07:09:27
The above tractor is a 1951 8N. Thanks
