OUCH!
Paul
01-20-2002 09:11:09
$27.33 plus tax for hyd. drain plug just because i had to give it one more little tweek.
Cajun
01-20-2002 13:47:31
 Re: OUCH! in reply to Paul, 01-20-2002 09:11:09
call sam monk 318 793 2808
Has used parts he will ship you one a lot less than $27.33
Tempororaly...
01-20-2002 11:59:05
on my 2n,I put the fill plug to the drain hole and put a plumbers test plug(cheap at Home Dopo) to the fill hole.Works fine till....
Paul
01-20-2002 12:19:17
 Re: Re: OUCH! in reply to Tempororaly..., 01-20-2002 11:59:05
I thought about doing that but i just put around $150 in the hyd. system and i could see myself going over a stump and peeling it right off and a while later every thing locks up.
Mark Hendershot
01-20-2002 09:52:34
Paul; I knew I should have saved all those drain plugs off that tractor! I gave the rest off it away with the rear end including the 3rd member gears. I could have helped you out. Mark H.
