Order Ford 8N Parts Online
Stuck valve on an 8N...
Paul MO
01-24-2002 12:15:53
I apparently have an exhaust valve (or two) stuck open on an 8N that has been sitting for quite some time. Is there something that I can pour into the spark plug holes or somewhere that might free it up or will I need to pull the head and do some more serious work?
Bill, MI
01-24-2002 17:11:44
 Re: Stuck valve on an 8N... in reply to Paul MO, 01-24-2002 12:15:53
I have the same problem with a 9N. It has been running fine. Started it up New Years day and was missing on number 4. No compression. New oil and filter last fall. Any suggestions? Thanks in advance.
Salmoneye
01-24-2002 12:44:08
Below is the reply I recieved from Zane in answer to the very first post I ever made on this board.
Worked like a charm on three of the exhaust valves...unfortunately I was unable to budge the fourth valve and had to remove the head to get the last one fixed.
I hope you are lucky and they all move for ya, but this is the way to do it!!!
