1) Read the manual carefully on the left brake and you'll see it has an interlock assembly which applies that brake when you apply the clutch. Properly adjusted, this can be a big help. 2) Because, unlike in automobiles and such, the gas tank is well above the carburetor and so the float valve is under constant pressure. Every float valve leaks a little bit. If left unattended with the gas on, eventually the carb will overflow, and the gas may fill the inlet tract, the air hose and (in extreme cases) the manifold, cylinders, timing chest and pretty much all of the engine. When you crank an engine in that condition, if the fire and explosion doesn't kill you, the damage done to the motor will make your wallet some sick. 3) Yes. That's how that loader works. No, it does no harm. 4) Doing leaky brakes is mostly hard dirty work, no great secrets to it. Be aware that 90% of oily brkaes are caused, not by bad seals, but by oil leaks through the shim stacks between the axle extension and the bearing housing. Attention to cleanliness and plenty of gasket cement here will pay a big dividend. HTH llater, llamas
