Oil Pressure- How much is OK?
Rick in Kansas
04-29-2000 16:56:39
Just rebuilt a 40's 9N engine. Tractor runs great. Good power, no smoke, no missing. When it is cold oil pressure is about 40lbs. on the the gauge. After about 30 minutes of mowing, pressure is at 20lbs. on the gauge, but this is as low as it goes. Mowed for 31/2 hours pressure never dropped below 20lbs. Is this sufficient oil pressure for long term reliability, or should I look at my main bearing clearance again.
Thanks for the help,
John
04-29-2000 19:13:08
 Re: Oil Pressure- How much is OK? in reply to Rick in Kansas, 04-29-2000 16:56:39
The owner's manual that came with the tractor states that it is normal to have the pressure drop to 20 after the tractor is warmed up. Sounds like you did it right!!
Keep smiling.
John :>)
...and the high side?
04-29-2000 19:28:19
 Re: Re: Oil Pressure- How much is OK? in reply to John, 04-29-2000 19:13:08
My 8N runs about 40 and really doesnt drop much. Do I have a problem? Waht would cause high pressure? Thanks
tom 8N396936
