Aftermarket sheet metal?
9N'er
04-29-2000 23:07:47
Has anyone purchased the aftermarket sheet metal products to replace original beat up, torn and rusted and you name it original metal? I am needing the lower l&R hood panels and grill...but I am concerned that the aftermarket sheet metal may not fit properly or be of lower standard weight/gauge metal. What has been the experience out there? 9N'er
9n'er
05-02-2000 08:50:07
 Re: Re: aftermarket sheet metal? in reply to ED-OH, 05-01-2000 13:10:03
I had an Uncle who recently passed away. He grew up in Hamilton, Ohio. Yep. I may go thre sometime if I am ever back in the midwest. 9n'er
truck
04-30-2000 19:08:55
 Re: Re: aftermarket sheet metal? in reply to ED-OH, 04-30-2000 11:17:36
Be sure to ask Tom about his used part stock.. He might even have a good used 9N hood. Last time I visited he had lots of lower side panels to choose from. As far as I know the only aftermarket hoods are for a 8N and require probably $150 in bodywork to fill the hole for the air filter door to make it look right on a 9N. Unfortunately the contour around the hood emblem is also different, and that would take some tricky bodywork to duplicate. If your hood isn't rusted in the lower sections, fix it and you'll be happier with the job.
9N'er
04-30-2000 05:17:05
 Re: Re: aftermarket sheet metal? in reply to Ed Gooding (VA), 04-30-2000 03:30:35
good comment Ed. Is it true someone may begin to fabricate true to spec sheet metal grills and hoods? I have been toying with the idea of getting into constructing true to spec 9n and 8N toolboxes.
bg
04-30-2000 10:39:11
 Re: Re: Re: Re: aftermarket sheet metal? in reply to Ed Gooding (VA), 04-30-2000 05:50:32
Wait a minute! What's this about something being "exactly" right? Can it be? I was led to understand that it did not matter....
Ed Gooding (VA)
04-30-2000 18:11:14
 Re: Re: Re: Re: Re: aftermarket sheet metal? in reply to bg, 04-30-2000 10:39:11
Well Bubba, for those who agonize over such things, Don Barkely and N-Complere can reduce your stress level, being hurricane induced and all that you know.
LOL..... ..... ..Ed
'52 8N475798
Michael Az.
04-30-2000 06:45:55
Ed, just recieved 8N grill from Don this week and it looks great. Good price too. Had a large order and he had everything I needed. Michael
truck
04-30-2000 19:11:38
 Re: Re: Re: Re: Re: aftermarket sheet metal? in reply to Michael Az., 04-30-2000 06:45:55
Were the grille bars teardrop shaped or round?
Michael Az
04-30-2000 19:20:10
 Re: Re: Re: Re: Re: Re: aftermarket sheet metal? in reply to truck, 04-30-2000 19:11:38
Truck, the bars are round. I think that is the only difference. You really do have to get your nose up to it to tell the difference.
Gaspump
04-30-2000 06:17:41
 Re: Re: Re: Re: aftermarket sheet metal? in reply to tom 8N396936, 04-30-2000 05:22:23
Stamped in? I heard they were applied on without stamping. Just curious as to which is right.
9N'er
04-30-2000 06:17:04
good suggestion. yes in fact, the grill and hood sides I have ordered are coming from them. But I suspect they are the same brand or factory makes as the other aftermarket itmes I read about. The prices are comepetive with the other companies or individuals selling aftermarkey parts, so I am assuming they are the same manufacturer
tom 8N396936
04-30-2000 05:16:00
Ed, if I can ask where did you purchase from. The feeling I am getting the quality depends on where it comes from. Just wondering.
regards
tom
Ed Gooding (VA)
04-30-2000 05:52:44
 Re: Re: Re: aftermarket sheet metal? in reply to tom 8N396936, 04-30-2000 05:16:00
>> if I can ask where did you purchase from. <<
ummmmm ..... .I bought it from YT when I first started coming here about 2 years ago.
