Order Ford 8N Parts Online
48 8N Block Available
Rob - CO
04-30-2000 10:37:08
I just rebuilt my 8N engine and replaced the cracked block. I don't want to toss the old block in the dumpster and wonder if anyone out there has any suggestions? I'll give it to anyone interested (you pay to ship).
The block will need sleeves but has good valve seats and all bearing surfaces are good, top is flat within 0.003 inches. The cracks are in the left side water jacket, one near the top and one near the drain cock. I used JB weld and the repair was working fine. the engine had no compression so I replaced the block on the rebuild.
Also have valves, springs, pistons (4 ring), oil pump, new carb kit, new cam gear.
