Order Ford 8N Parts Online
Bracket under the 8N's rearend
Paul B
05-01-2000 20:57:28
Need a little info please. Looked in the shop manual for this part mounted underneath the rear gear housing of my '52 8N but only saw a small picture of this 5" X 12" double layered plate/bracket, one layer flat, the other with two rises/humps. The flat side bolts against the under carriage. The end slightly projecting from underneath has about a 1 1/2" hole in it. What is this and what's it's use? I appreciate the info. Paul B
Ed Gooding (VA)
05-02-2000 04:02:34
 Re: Bracket under the 8N's rearend in reply to Paul B, 05-01-2000 20:57:28
Hi Paul: The picture below shows the whole enchilada, with the swinging drawbar that mounts to the bracket you described, and the drawbar stabilizers and the anti-sway bars connected beneath the fender mounts.
Hope this helps..... ..... Ed
'52 8N475798
third party image
John C. (IN)
05-02-2000 10:19:04
 Re: Re: Bracket under the 8N's rearend in reply to Ed Gooding (VA), 05-02-2000 04:02:34
Someday, I just gotta paint that ol' girl!
Ed Gooding (VA)
05-02-2000 14:09:01
 Re: Re: Re: Bracket under the 8N's rearend in reply to John C. (IN), 05-02-2000 10:19:04
Nahhhh, just scuff up those stabilizer/anti-sway bars to match up. It'll look correct!
LOL..... ....Ed
'52 8N475798
Jon. T.
05-02-2000 05:24:17
Ed & Paul, Right under the PTO is where "our" 12" plate is compared to yours which seems to be about 4" . Mine came with a trailer ball mounted on it, and is ideal for towing something with the hook-up down low so as not to upset the tractor backwards. It can also be "offset" to one side or the other for pulling trailer or piece of equipment.
Ed Gooding (VA)
05-03-2000 06:25:02
 Re: Re: Re: Bracket under the 8N's rearend in reply to Jon. T., 05-02-2000 05:24:17
There are two different kinds of swinging drawbars commonly used, one like pictured previously, and one that uses a bracket that attaches beneath and around the PTO to control the swing, like the one pictured here on my 3000:
third party image
Regards..... ..... Ed
'52 8N475798
will
05-02-2000 03:57:42
That bracket is the mounting bracket for the original swinging draw bar. The other end of the draw bar rested on the 26 inch lower lift arm drawbar that gave you up and down positioning.
CY (OHTN)
05-01-2000 22:10:52
Paul I belive what you are talking about is the drawbar mount. A 1.5" (1 and a 1/4 on mine) pin goes upward and is retained by a hairpin clip. A flat plate with a hole in either ends mounts here. The other hole in the other end is for a clevis pin or trailer ball or other attachment device like for a chain or hook. I belive the flat plate is also call a swinging draw bar. I'm quoting from the best of my knowlege which isn't much but there are a bunch of good people here who know much more then me and will catch it if i make a mistake or give you a better place to go for info.FWIW. Cranky8N.
