12 volt conversion
Babalouie
05-03-2000 22:24:30
I have read that a 1 amp 50 volt diode can be used in place of the side marker lamp as diagramed in nseries.com My question is this: Does the cathode end of the diode face the accessory post on the terminal block or does it face the P1 post on the alternator?
STUMP PULLER
05-04-2000 15:20:43
 Re: 12 volt conversion in reply to Babalouie, 05-03-2000 22:24:30
I WOULD USE A 5 AMP DIODE. MY 12 V CONVERSION USES A SWITCH AND I SEE ABOUT 2 TO 4 AMPS WHEN I EXCITE MY ALT.
Claus
05-04-2000 04:48:19
The anode faces the terminal block.
Happy Motoring
CLaus
