Order Ford 8N Parts Online
8N Attachments
Alan (Colorado)
09-21-1998 07:00:07
Has anyone have any ideas on the possibility (or feasibility) of hooking a log splitter up to an 8N (like where and how)?
Or, attaching a chipper/shredder to the PTO using a belt (already have chipper, but engine died).
Thanks Alan
cadplans...Dell (WA)
09-21-1998 14:00:03
 Re: 8N Attachments in reply to Alan (Colorado), 09-21-1998 07:00:07
Alan..... you might like to checkout "www.cadplans.com". They have do-it-yourself plans for #210 vert/horz splitter for 3-point. Also back-hoe's, loaders and alot of other 3-point useful attachments depending how handy you are ..... .Dell
Alan
09-22-1998 06:04:00
 Re: Re: 8N Attachments in reply to cadplans...Dell (WA), 09-21-1998 14:00:03
Thanks - will check this out. Appreciate it!!
Rick 8N KS
05-24-2000 15:29:49
 Stabilizer bars for 3PH in reply to cadplans...Dell (WA), 09-21-1998 14:00:03
Alan
09-22-1998 06:03:17
 Re: Re: 8N Attachments in reply to Mike H(Md), 09-21-1998 11:58:41
Thanks - it was a Wisconson 8HP, home made massive chipper/shredder, more steel in it then in the hood of my wife's car.
TimK
05-24-2000 14:19:19
 Re: Possible leaking head gasket in reply to Steve WI, 05-24-2000 13:45:47
I used a composit gasket I got from NH, and I don't think I had a choice. It looked to me like metal covered with some sort of composit material on the outside. But are you sure the head gasket is the problem here inasmuch as the head has no oil galleries. Do you have water in the oil pan ? Are you sure it's oil in the radiator. It could be just sludge from all the old anti-freeze left in for years. Generally, if you've got a leaking head gasket you should see bubbles in the radiator as you rev it up from escaping compression into the water jacket.
Bob (MN)
09-21-1998 07:34:58
Somebody told me that the old Fords are a problem with a 3pt log splitter because of one-way hydraulics. this is a little beyond my knowledge but i understand that a log splitter requires two-way.
