Rear rim paint
9N'er
05-25-2000 04:11:10
I'm looking for suggestions on a silver paint to use on the rear rims of the 1940 9N. I don't want to paint the centers/discs, but just the rims (they are apart right now, sandblasted, and ready for primer and paint). But, I suspect, that these rims will see some wear and tear as I work the tractor in around logs, brush, gravel and the like. So, I'm looking for a tough and durable silver paint. And, also, a suggested clear coat over the final top coat of the silver painted rims. Any suggestions?, brands?, good experiences with a tough-a#* paint? 9N'er
bob
05-25-2000 10:49:18
 Re: Rear rim paint in reply to 9N'er, 05-25-2000 04:11:10
have you thought about using aluminum paint? This is what i plan on using.
bg
05-25-2000 07:05:22
You can use an epoxy spray can or use catalyzed acrylic enamel.
The original rims were supposedly zinc or cadmium plated. Check out Eastwoodco.com for some nice satin rim paint. It should be durable enough, but you can always repaint frequently.
