I've been using Mobil 1 10W-30 since just after break-in of my engine more than two years ago. I have several observations: 1. I haven't experienced greater leakage with synthetics than with mineral oil. That isn't to say that synthetics won't leak slightly more, but from my experiences (and tests I've read) it's not as overblown as some of the anecdotal reports I've heard. 2. Cold weather startup is fantastic, even with my stock 6 volt system in subzero weather. This means no block heaters or crankcase heaters. 3. I change oil at standard intervals. I figure that synthetic oil costs me about $20 a year extra for two oil changes. That's cheap insurance. I do NOT regard synthetics as an excuse for not changing oil, or changing oil late. Incidentally, the "dirty" oil (and internal engine parts) stay extremely clean, so I don't understand the concern about grit. 4. In my other life, I work extensively with stationary automatic standby generators, the engines of which have a lot in common with N applications--they operate at relatively low, constant engine speed under continuous load, and often sit unused for weeks before being expected to start immediately and load seconds later. Most of these generators use Mobil 1 (it's the factory pour for some). I can guarantee that these engines, broken down after many hundreds of hours, look astonishing. Many of the internal parts look new, and the inside surfaces of valve covers look like new, without the slightest trace of sludge. Ditto for oil pans. There is no way anyone can tell me that engine life isn't extended by the properties of synthetic oil, changed regularly. 5. The actual properties of thermal breakdown of synthetic oils aren't particularly relavent to N-series engine, or other consumer engines, for that matter. First, I don't believe I'll be seeing a lot of flathead Fords with updraft carburetors at Indy this year. And secondly, every synthetic I know of breaks down at much higher temps than mineral oils. If a synthetic oil fails due to temperature, it's still going to have occurred later than with standard oils. I'm not saying that N owners need to change to synthetic, but I can't agree with the posts that maintain that there are no advantages for this application. There are.
