Order Ford 8N Parts Online
8N 208139 What Year?
Rick SWKS
05-26-2000 19:27:01
I have just purcahsed a 8N with a Contintental Belton Company Belly Mower. I am trying to learn as much about this tractor as I can. What is the lever for at says Draft on the label on the right side just under the seat. What year is it?
Also need infor on the Belly Mower. It was made in Belton Texas. Number on the Mower are KA 5 Ser. # 3863
Jhbue
05-26-2000 19:45:56
 Re: 8N 208139 What Year? in reply to Rick SWKS, 05-26-2000 19:27:01
Hey Rick-Glad you found the numbers on the mower now find the numbers on the block of your 8n and repost your question.Someone will help you.Take care-Jhbue
Russ in SoCal
05-27-2000 00:06:26
 Re: Re: 8N 208139 What Year? in reply to Jhbue, 05-26-2000 19:45:56
Looks like a 1950. Check the gray column to the left. Down under "Research & Info," click on "Serial Numbers."
Russ
8N58182*
Salmoneye
05-27-2000 00:08:15
 Re: Re: Re: 8N 208139 What Year? in reply to Russ in SoCal, 05-27-2000 00:06:26
Try the link below for all your Ford serial number needs...
Paul II, In Vermont
