Order Ford 8N Parts Online
Where can I get a head gasket for an 8N?
Rambo
10-04-1998 17:54:06
We have an 8N that we are tring to get running and it is leaking water and we are hoping that a new head gasket with fix that problem. Hoping that theres not a crack some were? Where can I find a gasket????? ???
JOHN
10-05-1998 21:06:11
 Re: Where can I get a head gasket for an 8N? in reply to Rambo, 10-04-1998 17:54:06
Greetings!
Quickest way to a head gasket (and good a price as any, better 'n some) is Yesterdays Tractors, which hosts this web site; I had a siilar problem and fortunately had the presence of mind to take the head to a local machine shop. They found that there were several hairline cracks (and a former repair job), therefore needed a new head (also available from YT). Recommend also checking the block for true, hopefully it is ok and there is no other cracks for fluid to leak out. Is this leak just out of the head/block area, or is there water in with the oil, or oil in in the radiator water?
As ol' Joe Bob Briggs used to say "check it out."
JOHN :>)
TimK
10-05-1998 15:23:03
You should find a head gasket easy enough as evidenced by the responses to your message. However, I would if I were you really explore as to why that head gasket failed, e.g. did it overheat and why, is the head flat, is the block warped, are the head bolts all there and are the studs good enough to allow for proper torque down ? You do not mention if you owned the tractor prior to it's failure, so I assume you did not.
Bill (MO)
10-04-1998 18:49:31
I am from a small(5000) farming town and the local parts store(automotive) carries such exotic(?) things there. If your store dosn't have it can they order it? ASK and you shall pay and receive!
good luck
Bill
Mike B
10-06-1998 19:39:15
 Re: Re: Where can I get a head gasket for an 8N? in reply to Bill (MO), 10-04-1998 18:49:31
Fel-pro Gaskets still carry them for the 8N
jake from il
10-04-1998 18:33:44
NH dealer and CT both have em
John Holmes
10-04-1998 18:17:48
The good folks at YT. have several parts advertisers, scroll up and click on parts.
billy bob
05-29-2000 18:37:03
 Re: Re: Ford Hydraulic Tools on eBay in reply to marv, 12-23-1999 17:57:34
Daaaaa aaaaa aaa---huh
