Rear blade ford 2N
Sam
11-19-2002 21:05:21
I have recently purchased a 2N and i was wondering how efficient a 6 foor rear blade for snow works, is it better to push backwards or pull it forward. Do i absolutely have to have snow-chains in order to plough snow effectively. Thanks
Paul (WI)
11-20-2002 18:25:47
 Re: rear blade ford 2N in reply to Sam, 11-19-2002 21:05:21
If you want to keep from damaging your concrete I would say to leave the chains off. I did some repairs on a friends 9N a couple of days ago and just driving normal with chains and loaded tires put little nicks in the concrete. I would think that there would be some very serious damage after a winter of plowing snow at plowing speed. I do not use chains and can move quite a bit of snow if I don't let it get too deep. I back up a lot and push it into banks and if they get too high I use the scoop to haul some of it away. A lot of momentum helps when backing it into piles and I raise the blade just before I hit the pile. Yeah, I get stuck every so often but it works for me. Deciding if you should use chains depends what type of surface you have to plow and the weather conditions that you face.
Danny in CO
11-20-2002 06:08:54
I use a 6' with my 8N and it works great. I think a 7' might actually be better for snow. Here in Colorado, the snow is light and fluffy. If I use the front side of the blade, it bites in too much. Most of the time I turn the blade around and then pull forward using the back side of the blade to push the snow off to the side. I angle the blade to one side or the other.
Danny
try this==bj/8n/mt
11-20-2002 08:36:41
 Re: Re: rear blade ford 2N in reply to Danny in CO, 11-20-2002 06:08:54
If your blade "bites in too much" adjust the top link on the three point to change the angle of attack. Trial and error will show you where to set it.
Your mileage may vary
Dan S
11-20-2002 05:16:28
I was also considering chains but was wondering how much they would tear up my paved driveway. What damage do the chains cause, if any?
Dan
Sal
11-20-2002 14:18:48
 Re: Re: rear blade ford 2N in reply to Dan S , 11-20-2002 05:16:28
I use a 7' blade, filled tires and Field chains. This set up works great here in Upstate NY.
If you spin the tires they will chew up an asphalt or concrete drive.
Also if you lock one of the brakes and spin the tractor you will gouge the drive-way.
One thing I would suggest is to install a rear work light if you don't have one...makes plowing a lot safer and easier in the evening when it gets dark at 5:00.
Sal
ED-IL
11-20-2002 09:01:31
I don't know about driveay damage, but remember to keep hands, coats, gloves, etc. away from the tires with chains on. Chains like to grab and after they take your arm, it is a short trip to the underside of the tire.
Jim in NS.
11-20-2002 05:27:39
A 6' blade works good on my 2n. I dont think I could get along without chain's (lots of snow in NS.)Chain's dont seem to hurt my pavement. I try to avoid spinning the wheels as much as possible.
MikeC
11-20-2002 03:55:19
third party image
I have a 7' blade that I use. Even with the rear wheels set wider I can still clear a path the width of the wheels. The chains question really depends on the type and amount of snow that you get. Light occasional fluffy snows and you might be OK without. Big heavy wet snows (like here in Central Iowa) and I couldn't get back up the driveway without the chains. However, with the chains and loaded tires I can plow both uphill and downhill.
A couple of years ago we had some real heavy snows. As I was pulling the snow along the edge of the road my front wheel hooked a rut and yanked me into the ditch. The snow was drifted about 4' high and in order to get out I had to gun it and make a large loop through the front yard with an average of 2' or so of snow. With the chains there was never any hesistation that I would be able to drive out of it. Without the chains I suspect that I would have pulled it out with something else.
The neighbors all saw the tracks and accused me of playing when I should have been working!
BOB
11-20-2002 18:55:41
 Re: Re: rear blade ford 2N in reply to MikeC, 11-20-2002 03:55:19
Mike i had one of those loaders on my tractor for awhile,sure gets old gittin on that jungle jim set
anyway your tractor looks nice BOB
ED-IL
11-20-2002 03:24:33
I have a '46 2N and I use it for snow removal.
Third Party Image
Here is some advice.
#1, Get a Zane Thang.
It is an aftermarket device manufactured by Zane Sherman (a frequent contributor) that gives position control to the three point hitch. Without it, the 9N and 2N must rely on the ground to set the level of the blade. That can be a problem with wet heavy snow. The position control allows you to set the blade an inch or more above the ground, which adds weight to the rear tires, and eliminates the friction of the blade against the ground. It seems strange, but my tractor won't move 4" of snow with the blade all the way down, but it will move more than 12" with the blade slightly off the ground.
#2, Push or Pull.
You will need to do both. The best advice is experience. I have a 6' blade, that I keep slightly angled to the right. I live next door to where I work and have to do the parking lot too. For my driveway, I drop the blade and drive down and up, pushing the snow to the side. For the parking area, I take several foreward passes, then push the accumulated snow to a stockpiling area.
#3, Have a plan.
Depending on your winter conditions, that snow will start to gather. Plann where the stockpiles will be and set aside areas you defibitely don't want blocked, such as intersections where visibility is important.
#4, Play Mechanic. In colder temperatures, the older tractors might need a little care. Some guys get dipstick or magnetic heaters for the oil pan to help them get started. Carburetors have been known to ice up and condensation can also play havoc with the front mount distributor (especially when packed with snow) which takes you out of the snow plowing game. ALso, check that hydr. fluid for water now. If it is a milky caramel color, it is probably going to freeze up, and usually in a position you don't want.
#5, SMile.
Plowing snow with the N is a great deal of fun (especially the first time you fishtail). But make the fun last. By the time Febuary rolls around it starts to loose it's charm. Pace yourself, and dress warmly.
Steve W
11-20-2002 06:10:01
 Re: Re: rear blade ford 2N in reply to ED-IL, 11-20-2002 03:24:33
What Ed said..... ..
jim
11-20-2002 06:36:56
 Re: Re: Re: rear blade ford 2N in reply to Steve W, 11-20-2002 06:10:01
I would recommend a 7' blade as a 7 footer clears your rear tires. Placed on a slight angle , you'll move a lot of snow with little side push. Don't forget to use a sway bar or you'll have a lot of fun. As for the chains , I always feel that, not having chains , you have a built in feature that will result in not overloading the drive train , as you'll spin before breaking something. But then ,I live on fairly level ground and don't have a problem with hills.
Willy-N I Forgot about the blade part
11-19-2002 21:27:38
Yes the 6 ft will work but a 8 ft is better then it will clear your wheel base even when on a angle. Mark H.
Willy-N
11-19-2002 21:24:42
Works better pulling it but you need to push it sometimes to get it out of the way. You can move snow without chains but you can move a whole bunch more with them. Just get ready to buy a set this year after the snow falls then you will wonder how you ever got along with out them. Mark H.
