It always ends up being the little aggravations...
9N'er
11-20-2002 04:09:25
Some of you know that I am restoring a 61 Ford 801 with an Elenco 4WD. After a complete engine, transmission, and rear end overhaul, it was then trailered to the local body shop last Monday.
Since then, I told the wife she would not be seeing me much until it was painted and I have kept my promise.
For the past 8 days, I have been working on it (after work) from 4PM til 9, 10, 11, and sometimes (like last night) coming home at 11:50 PM.
Without much fanfare I have been alone with my thoughts and grinder in a grimy and dirty back stall of this body/repair shop grinding away with wire cup brushes on a 4.5 inch grinder removing paint, grease, and 42 years of dirt, and scraping at hard to reach areas with spatulas, picks and what else; using a heat torch to free-up rusted nuts and bolts, welding front axle braces, and doing all of that dirty, time consuming, and particular work for a nice job; washing, degreasing, wiping down, cleaning, and prepping.
And don't let anyone tell you that tractor restorations isn't a lot of WORK! IT IS WORK! Time consuming, dirty, and meditative WORK!
Saturday I primed it, and that night I painted the main frame.
Began re-assembly on Sunday, continued with that Monday, and last night as well. Dash is on, all gauges wired in, fluids filled, power steering pump rebuilt and seals replaced. Installed seal on the hydraulic pump, polished up the gas tank, sanded it shiny new, installed heat shield, radiator, front wheels, filled the tank with gas, double checked all my wiring, connections, and turned the key, pushed the starter and VOILAH! varrooooo m, a black cloud pushed out back, ran to the other side, adjusted the distributor and timing, and she evened out and purred like a kitten.
Until..... ..
'you know the oil pressure line?' that goes from the block to the oil pressure gauge? The one that has no convenient reach unless the hydraulic pump is removed? It blew out. Right behind the pump because it was old, probably rotted and with moving it around a hairline crack developed and now I had I surge of oil coming down the side of the block.
And, of all the parts I replaced...the oil pressure line was the one I didn't replace. Go figure.
Ahh well, that's the way it goes in antique tractor restorations. The little things, and the one thing that may skate by, and it's the one that either aggravates you when you're beat tired and haven'tt eaten since breakfast, and it's late, and you were hoping the end was on hand and you could go home without having to do "one more thing." Or, one part of long process that you say...'hmmm that's not so bad...at least it started and I'm making progress.'
I guess it depends on the mood...but this I know...I'm beat tired and I'm ready to go back to a normal routine and I'm wondering, alone in my back stall, dirt hanging in thair, exhaust fans running, compressor kicking on and off, pants black again, hands creased with dirt and grease, hair matted with overspray, and it's getting late into the night I ask: "why am I doing this? why I am I here?...what's the meaning of all of this"
9N'er
tlak
11-20-2002 16:23:41
 Re: It always ends up being the little aggravations... in reply to 9N'er, 11-20-2002 04:09:25
Not so long ago you asked HOW now you ask WHY. We can only perform one miracle at a time.
Brian-2N
11-20-2002 14:19:52
As they say at M.I.T., Defecation Occurs. I know you want to finish, but sometimes you need to step back a couple of paces and gain a new perspective. Take a break and start again this weekend. The weather's going to be crummy, so it will be a good chance to work inside.
Willy-N
11-20-2002 12:27:51
Now you know what I go thru every time I get one ready for eBay! The cleaning part is the most fun part of all!! It is work that is why you do not see many clean parts listed by others. Mark H.
That we know! Dave OH
11-20-2002 21:51:39
 Re: Re: It always ends up being the little aggravations... in reply to Willy-N, 11-20-2002 12:27:51
The block I got from you was CLEAN thanks.
Dave OH
Willy-N
11-20-2002 22:23:27
 Re: Re: Re: It always ends up being the little aggravations... in reply to That we know! Dave OH, 11-20-2002 21:51:39
My next project is to restore a Military M-37 3/4 ton Truck. I am working on getting one sorta like the Power Wagons. Mark H.
Dave OH
11-21-2002 15:03:42
 Re: Re: Re: Re: It always ends up being the little aggravations... in reply to Willy-N, 11-20-2002 22:23:27
My friends restore military vehicals, which can be quite chalenging. We meet at Military Shows where there are everything from tanks, both American and Russian down to the Mule. Which I like but the prices have soared on the Mule.
Great for around a farm.
Dave OH
Why not a military Sherman?
11-21-2002 00:48:28
Whay not a Sherman TANK for your next restoration? I hear their over-unders are kind of rugged. Think what that will go for on ebay. bill
Yep
11-20-2002 10:11:19
Yep,
Last night around 11 I removed the last bolt from my 8N transmission to remove it from the already spit tractor. I'm covered in grease from stem to stern. As the last bolt was removed I grabbed the transmission and started carrying it to the corner of the shop. (They are pretty heavy with all the gears in there) About that time my wife opened the garage door and calmly ask me if I could help her with the girls (2.5 and .5 years respectively). I could hear them both screaming their heads off. Hmmmmm .. By the time I degreased myself they were asleep soundly. So it goes. Wouldn't trade them for all the 8N's in Virginia though! Denton
Yep
11-20-2002 09:39:10
Yep,
duey
11-20-2002 08:49:28
Hey 9N'er, cheer up.... they say don't go shopping when you're hungry....you'll buy everything, it all looks good.
There is absolutely no substitute for personal satisfaction. None. And that is truely what you're getting back. "I did it myself, yessir!" THAT is the work of my hands. My head. My aching back. MINE! What others say of my work, what they think of my work is their own opinion, good or bad, and it takes NOTHING away from my satisfaction.
Although I'm sure the Elenco makes it substantially more difficult, all in all, it sounds like you have had the same issues all have faced in their tractor travels.
Hang in there, in a week you'll be thinking about ANOTHER project... this stuff is addictive and I love it!!! Enjoyed your post!!
Its better than.....(8ndexta-ger)
11-20-2002 08:16:55
it's better than watching TV.
SteveB(wi)
11-20-2002 05:42:42
Just went through the same deal with my old pickup, replaced all the sheetmetal from the bed forward and a new engine, frame paint etc. The long nights in the shop get old, especially as the nights got colder. The personal satisfaction from doing it yourself and having a nice piece when you are done are worth it.
Barnstormer
11-20-2002 04:26:25
That answer will come when you go to your first show and get the O-oooo-s and A-aaaaah-s and all of the questions.
