Governor
roger powell
11-20-2002 12:56:28
WELL,IAM BACK AGAIN. I HAVE A 9N ENGINE AND I KNOW THAT THE GOVERNOR FOR A 9N HAS 3 LEVERS BUT THE ONE ON MINE HAS 2 AND CONNECTED TO THROTTLE AND CARB WITH ADJUSTABLE RODS JUST LIKE ON A 8N.THE HOUSING IS STAMPED 9N,SO HAS SOMEONE CHANGED LEVERS(IF THIS IS POSSABLE,AND STILL WORK)OR ARE THE HOUSEINGS INTERCHANGEABLE?? ANY HELP WOULD BE APPRECIATED.THE SERIAL NO ON ENGINE IS(9N250080) I NEVER REALLY RAN THE ENGINE SO I DONT KNOW IF GOVERNOR WORKS OR NOT.GOING TO REBUILD THE ENGINE THIS WINTER. THANKS IN ADVANCE AND WILL MORE THAN LIKELY BE BACK ONCE I START REBUILDING.
don b
11-21-2002 09:49:04
 Re: governor in reply to roger powell, 11-20-2002 12:56:28
You can put an 8n gov. on a 9n engine or a 9n gov. on an 8n engine.[frt. mt. dist.]What you can't do is.....put an 8n gov. on a 9n tractor or a 9n gov. on an 8n tractor.The linkages are all diff.except the linkage from the gov. to the carb.I'm sure this is clear as mud.Anyone who does not understand what I'm trying to say ,can call me at 1-888-355-9937 and I'll be glad to explain in detail. don
Steveb(wi)
11-21-2002 10:38:59
 Re: Re: governor in reply to don b, 11-21-2002 09:49:04
What your saying is they will bolt to the engine but not connect to the carb?
don b
11-21-2002 13:23:55
 Re: Re: Re: governor in reply to Steveb(wi), 11-21-2002 10:38:59
Yes, they will bolt to the engine and connect to the carb.BUT....the throttles and throttle linkage is diff.and can not be swapped from an 8n to a 9n or visa versa. don
Dave Smith
11-22-2002 04:01:47
 Re: Re: Re: Re: governor in reply to don b, 11-21-2002 13:23:55
Don, Will a 8N gov work if you use the throttle arm from a 9N gov on it? Looks like it should.
Dave <*)))><
don b
11-22-2002 09:20:52
 Re: Re: Re: Re: Re: governor in reply to Dave Smith, 11-22-2002 04:01:47
That's not his problem.He has a 9n engine in his 8n,which is no big deal.The 9-2ns have a long throttle rod that bolts to the top of the engine and runs from the dash to the front of the engine.8ns do not have this set up.9-2ns have a short linkage that connects the throttle lever to this rod at the dash and a long linkage that connects it to the gov.at the other end.Also a linkage that connects the gov. to the carb.This linkage is the same on 9-2-8ns.The only diff in the 8-9-2n gov. is the arms[frt.mt.dist.] don
DON TX
11-20-2002 18:34:22
My manual shows 2 levers on the 9N. HTH
DON TX
great.............bg
11-20-2002 14:34:15
How 'bout turning off the CAPS LOCK on your keyboard? It makes your posts easier to read. Thanks.
mike
11-20-2002 16:29:06
 Re: Re: governor in reply to great.............bg, 11-20-2002 14:34:15
Tractor repair and internet etiquette is what we're here for. Thanks, I agree.
roger
11-20-2002 16:49:01
 Re: Re: Re: governor in reply to mike, 11-20-2002 16:29:06
bg&mike thanks for the etiquette lesson. will try to be a bit more civilized in the future.happy thanksgiveing to all.
